2002 TA switching long blocks - lots of ????????
Are the crank and cam sensors the same?
Are the crank and cam sensors in the same location?
Can I swap the main pulley from the LS1 onto the LQ4?
Both heads are cathedral port so not worried about intakes BUT anything i should know going to 317 heads?
Hoping everything simply swaps over and i could just go.
I am aware of the longer crank stuff for the 4L60 = Not worried about that.
Thanks for your help.
Are the crank and cam sensors in the same location? YES
Can I swap the main pulley from the LS1 onto the LQ4? YES, as long as you use the LS1 accessories
