Oil leak in back of motor
Old Jul 31, 2021 | 12:57 PM
D_himmberger's Avatar
Default Oil leak in back of motor
I have an 06' Sierra with the aluminum block 5.3. I have a pretty bad oil leak on the top, rear of the motor and it leaks down to the bellhousing. So far I've replaced my rear main, valley cover gasket, oil pan gasket knock sensors, cam sensor and oil pressure sensor. I don't know what else could be leaking. If anyone else has any idea on what it could be I'd really appreciate it. Thanks
Old Jul 31, 2021 | 01:26 PM
Check any PCV line running across there for cracks or seepage.
Old Jul 31, 2021 | 01:38 PM
I will check again. But I replaced the driver's side PCV with rubber hose. my port for the passenger side is broken on my intake. Currently I have a breather tube on the front of my pass. side valve cover
Old Aug 2, 2021 | 10:36 PM
64GunPilot's Avatar
Oil pressure sender may be bad and leaking.
