Cam suggestion
Old Aug 19, 2021 | 02:50 PM
Mike Cordero's Avatar
Default Cam suggestion
Im assembling a lq block bored to .030. It has stock crankshaft but 6.125 compstar rods and flat top diamond racing pistons. Arp studs and arp head bolts. 243 heads with with sodium filled/hollow stem valves and 660 comp cams 921 springs, new ls2 chain, new melling high pressure oil pump, ls1 lifters, ls6 intake manifold, ati balancer. Has no car for it right now. Looking to get a street/strip cam, that can take advantage of the present parts to the max on occasional racing but tha can be use on street too. Not having a car now, dont know if is going to be used in a manual trans car or automatic. Know that will need a converter for an automatic car. Last thing, thinking that probably will sell the engine, the cam should be something affordable. Any ideas/suggestions ???
Old Aug 19, 2021 | 04:07 PM
BigDaddy97's Avatar
The Summit Stage iv or Cam Motion Titan King would be great with this setup. I would swap the intake for a Fast 102 or MSD Atomic.
Old Aug 19, 2021 | 04:16 PM
Originally Posted by BigDaddy97
The Summit Stage iv or Cam Motion Titan King would be great with this setup. I would swap the one intake for a Fast 102 or MSD Atomic.
Thanks for your time.
Old Aug 19, 2021 | 04:37 PM
low2001gmc's Avatar
MASS seller approved
Because you state AFFORDABLE and may resell, I would leave it up to potential buyer.
If unsure and still want AFFORDABLE, I would look for a deal on a cam, new or used, or go with a Summit Cam.
If you decide on Fast Intake, then I have a Cam Motion Titan King, 236-244, 621-604, 112+3 Cam, new in box, for $325 shipped and paypalled.
It all comes to budget and goals. Good luck.
Old Aug 27, 2021 | 07:09 PM
Default Cam
Someone have for sale a good used cam which will takes the most of this parts?
Old Aug 29, 2021 | 09:15 AM
cula8r's Avatar
https://www.pro-touring.com/threads/...3-LS3-camshaft
Old Sep 2, 2021 | 04:44 PM
00pooterSS's Avatar
Those hollow/sodium filled valves are longer than all the other typical LS valves, make sure you measure for proper length push rods
You'll need shorter push rods due to those valves
Old Sep 2, 2021 | 05:49 PM
So THAT'S where the different length valves come in! Thanks for the clarification Pooter!
Old Sep 2, 2021 | 06:41 PM
LS7 intake valves are shorter also. Lash caps make up the difference.
Old Sep 2, 2021 | 09:36 PM
We are awash in LS knowledge here.... anybody wonder how you CAN'T learn something around here??? It never ends....
Old Sep 3, 2021 | 11:19 AM
00pooterSS's Avatar
I thought about writing "except LS7" but wrote "typical LS motors" instead
I see the LS7 as a non LS lol.
I should have written something about the ls7, thanks for clarifying scott
Old Sep 3, 2021 | 11:20 AM
00pooterSS's Avatar
Yessir. If I recall correctly, they are .027 longer.
Someone should look that up before taking my word on it though.
Old Sep 3, 2021 | 12:23 PM
gjohnsonws6's Avatar
Im putting together a cam only LS2 right now, went with the EPS 234/246 based on peoples success with it. Geoff at EPS is awesome to work with. In the end it all boils down to application.
