Marine rods and pistons?
Even if they might be less appropriate for higher HP shorter 1/4 mile type things than Gen 4 or aftermarket rods, i'm looking at a towing application wanting higher constant loads - like a marine engine sees and someone said even Gen 4 rods run HARD will make the big end out of round over time. (I dont know about it one way or another just what another commenter posted)
I did a search for 'marine rods and pistons' and saw no topics so I created a new topic. I thought this would be of interest to others doing such a search in the future, in case others want to see a discussion about it or would never know of it being mentioned in a different topic. I wasn't meaning to spam the board, just keep information separated so someone doesn't have to dig through 50+ posts in my original root post.As I get feedback or hear of something totally new, plans refine and change or are replaced by better ones. I updated my original thread with project plan changes if it matters and wont recopy it all here.
Bottom line - marine engine builders do many things when designing an engine for marine use due to the application.
Please know - You could melt a custom piston if not keeping all critical engine parameters in check including tune.
https://www.google.com/search?q=ls+e...client=gws-wiz
https://www.summitracing.com/parts/s...make/chevrolet
The risk of melting parts is another reason I wanted to start with a 'junkyard' 5.3L unrebuilt for my first attempts at tuning. Rather kill a $300 core than a $1000 core 6.0L. Once i've learned enough to feel competent on that i'm wanting to upgrade the internals and freshen the engine up so I feel more confident about going longer distance and raising boost. This is ALL a learning experience for me, i'm just bouncing the plans off many minds (already modified things that people that know more than me talked me into altering) to try learning with words instead of broken parts, but some things i'm willing to try and learn that way if the idea just seems a bit untested or at least not verified as a bad one.
