Cammed 6.0 possible head issue
Old Sep 1, 2021 | 08:04 AM
mitchelc's Avatar
Default Cammed 6.0 possible head issue
Hello all, Colin here. I think i may have an issue with my heads/gaskets
Runs well, but i loose a gallon of coolant about every 2 weeks or so. the oil cap has a fair amount of condensation on it, and the inside of the pass side valve cover is MILKY. The substance smells like oil, not sweet
Is there anything i can do to test this? It runs great and looses coolant slowly. But, the sludge and loss of coolant is def pointing towards a head issue. its a cammed 6.0 with milled heads and i had the heads checked as well. 317 heads. please help!
Old Sep 1, 2021 | 08:23 AM
LilJayV10's Avatar
pull the plugs and see if there are any that look different than the others.
do a compression test
pressure check the coolant system
Old Sep 1, 2021 | 08:35 AM
mitchelc's Avatar
All plugs look the same. I will have to pressure test!
Old Sep 1, 2021 | 08:52 AM
LilJayV10's Avatar
Leave the plugs out while you are doing a pressure test.
