2004 Pontiac GTO
I am in need of some assistance in locating where an engine code number would be located on a LS1 5.7L that is in a 2004 Pontiac GTO. Any quick help would be greatly appreciated
Thanks
Besides the displacement number on the block you can find the engines manufacture date to see if it corresponds with the vehicles model year. If it's off the engine has probably been replaced. That said vehicles manufactured from August through December are usually the next model year.
The letter/numbers cast into the block under the head at the front of bank 2 are the manufacture date.
K134 = November 13th 2004 on my LQ9 that came from a 2005 Escalade.
Attachment 712605
A better way to approach this might be, to go DIRECTLY to the thing you actually want to know, such that you can extract useful, actionable, accurate information on which you can reliably base a decision. The stamping code IS NOT that. What is it you REALLY want to know, that you think that code will tell you? What will you do differently depending on what that code would tell you?
As it would turn out the engine from my C5 was in fact most likely swapped in from a 2004 GTO or an '04 C5. I identified this based on the block itself, the Gen 4 rods in it, the style of camshaft gears, and the cylinder head bolts required. A thing to note, though, things like the heads and cam shaft gears are not necessarily good identifiers as they are easily changed for various reasons. Knowing that the revised bolt pattern was introduced in late '04, as well as having press fit Gen 4 rods with Gen 3 pistons, were the only true identifiers I had.
What are you trying to figure out, specifically? Because simply looking at the code or bullseyes on the block to identify LS1 block or LS6 block will not tell you the entire story.
Hope this clears up what I am talking about. If there are any further questions, please feel free to PM me.
thanks
A swapped-in motor is not likely to be "all-original". Therefore the stamping code, EVEN IF you could "decode" it down to the individual vehicle it came from, is not likely to tell you the whole truth about it. It is more likely to lead you astray in unpredictable directions. It is USELESS.
