v wont stay running
Old Sep 29, 2021 | 12:13 PM
v84u2nv's Avatar
Default v wont stay running
need help 05 v starts up revs to 3500 then shuts right off it is setting a cam sensor code at the moment . swapped out the comp with the vats deleted nothing changed same problem swapped a mass air flo to same thing have good fuel pres 55lbs grounds all look good need some good advice thanks
Old Sep 30, 2021 | 08:25 AM
Old Buzzard's Avatar
Try the tune/diagnostics forum...............
Old Dec 8, 2021 | 10:35 AM
azhuiaj's Avatar
The simple fix to this is to TAKE CARE OF YOUR VEHICLE. By this: Don't let it sit around for weeks or months on end without running it. Maintain all fluid levels. Use fuel additives like Injector Cleaner or Sea Foam.
Tutuapp 9Apps Showbox
Old Dec 8, 2021 | 11:12 AM
And here you are over 2 months later with irrelevant advice, besides totally copying a post in another thread with worse English than it was in the first place
Old Dec 8, 2021 | 02:04 PM
Troll!
