Engine building guides?
Old Oct 17, 2021 | 11:13 PM
Chonda's Avatar
Default Engine building guides?
What’s the suggested book or guide to use to assemble our bottom ends? I’m building a boosted 402 and instead of just googling the specs I want to get or follow the most recommended stuff I can get. Also is there a hood in depth fast 102 porting guide or because I’m boosting just leave it?
thanks
Old Oct 17, 2021 | 11:46 PM
If you are boosting, leave it alone.
Old Oct 18, 2021 | 12:26 PM
99Ls1fever's Avatar
Here is a link to torque specs:
https://paceperformance.com/files/pd...rque-specs.pdf
https://www.jegs.com/tech-articles/ls-engine-specs.html
Threads:
https://www.tbssowners.com/threads/4...ecklist.72850/
https://www.ls1gto.com/threads/guide...-a-402.531186/
https://ls1tech.com/forums/generatio...ls2-build.html
https://www.motortrend.com/how-to/08...-engine-build/
If you are boosting it, like G Astma said I would leave it, I made almost 4 digits on a stock LS6 intake. There is Engine Masters that goes over this on Motor trend, where they test all these different cylinder heads and they power never really changes, just the amount of boost (which is a measure of engine restriction). So on the efficient motor it made less boost. Where the stock headed motor, had higher boost number ( more restriction).
Old Oct 18, 2021 | 12:43 PM
99Ls1fever's Avatar
Moderators might move this to the LS2 section and it will get more views....
