Reassembling engine after cleaning/no oil in bearings
Old Nov 26, 2021 | 10:08 PM
glamisbound's Avatar
Default Reassembling engine after cleaning/no oil in bearings
Like the title says, I tore my ls1 down to bare block minus the crank. Polished rod journals, honed cylinders, so I’m cleaning it thoroughly with wd and brake cleaner. My fear is that in doing this it strips the oil from the main bearings. Will turning them over dry (not fired up) hurt anything till oil is able to get there?Obviously all other parts will get assembly lube on install but don’t want to pull crank for a couple reasons.
Old Nov 26, 2021 | 10:52 PM
SoCalDave's Avatar
Use some assembly lube or oil to lube the bearings while the engine sits.
Old Nov 26, 2021 | 11:03 PM
On the bearings I have access too, cam and rod bearings yes of course. But I won’t be pulling the crank main bearings, those are the ones I’m concerned about, seeing if it’s alright to turn over initially without oil in there, or a different way to send them oil without disassembly.
Old Nov 26, 2021 | 11:12 PM
SoCalDave's Avatar
You can use WD-40 to lightly lube as you turn the crank. Otherwise the only way I know is having the main bearing caps off.
Old Nov 27, 2021 | 12:55 AM
LLLosingit's Avatar
Build a cheap pressure pre-lube setup. Here is one video but you can build one out of a cheap pump type
Weed Sprayer Weed Sprayer
Video: Building a Homemade LS Pre-Oiler
Old Nov 27, 2021 | 01:44 AM
Build a cheap pressure pre-lube setup. Here is one video but you can build one put of a cheap pump type Weed Sprayer.
Bingo! That’s what I was lookin for. Thank you!
Old Nov 28, 2021 | 01:55 PM
SoCalDave's Avatar
One other thing you might want to do is to run oil through your oil pump before you install it. I recently helped with an LS2 refresh for an '05 C6 using assembly lube on all the bearings, putting oil on the underside of the pistons, WD 40 on the piston rings, and the oil pressure came up almost instantly.
Old Nov 28, 2021 | 09:08 PM
RonSSNova's Avatar
Since you have the rods/pistons out, just pour oil into the oil holes at the rod journals. Oil squirt can works.
Those holes lead directly to the main bearings.
Old Nov 29, 2021 | 07:01 AM
I was going to suggest this also, but I’d be afraid to do this and push cleaning debris through. This thing really, really needs the crank out and washed. Wouldn’t take another couple of hours.
