Another cam install ?
Old Jul 21, 2004 | 04:12 PM
NAVYBLU-Z's Avatar
Question Another cam install ?
Hi guys:
Ok..I got myself a Sears valve spring compressor, I guess this would be the conventional type that has two prongs that go on the bottom of the valve spring while it pushes down on the spring/retainer as it is compressed. My question is will this even work for removing the springs on the #7 & #8 cylinders? It doesn't seem like it will being that they're buried under that damn cowl...If not, please let me know so I can return it and get that one that More sells. I don't want to be that far in the install and not be able to get those 4 springs off of #7 & 8.
Thanks!
Old Jul 21, 2004 | 04:16 PM
Tranzor's Avatar
Very few spring compressors out there will work on the #7 and $8... I would go with either the More tool, the Vinci tool, or something like the Larry tool if you want to save some money.
Old Jul 21, 2004 | 04:17 PM
NAVYBLU-Z's Avatar
Thanks, Tranzor...
I know where to get the More one...Where can I find the others you mentioned?
Old Jul 21, 2004 | 04:19 PM
jrp's Avatar
jrp
SN95 Director
Originally Posted by NAVYBLU-Z
Thanks, Tranzor...
vinci is a sponsor and check the tool section for the larry tool.
Old Jul 21, 2004 | 04:21 PM
NAVYBLU-Z's Avatar
Cool, thanks JRP. I'll check it out...
Old Jul 21, 2004 | 07:28 PM
ss rally red's Avatar
I have a more tool but would like to add a Larry tool to the collection' been waiting a while now.
Old Jul 22, 2004 | 03:44 AM
35th SS's Avatar
I used the more tool on my swap and went along smood until I got to #8.damm 2hrs for that spring and finished it.It can be done just need alot of patience.
Old Jul 22, 2004 | 12:13 PM
NAVYBLU-Z's Avatar
Whoa! 2 hours?! That's like 4 beers later and by that time I'd have to stop and continue the next day =)...Anyone out there swap those springs out pretty easily, please let me know what you used. Thanks!!!
Old Jul 22, 2004 | 02:18 PM
Taspeed's Avatar
i have the sears tool and it works just really tight and cramped under there.
Old Jul 22, 2004 | 02:32 PM
NAVYBLU-Z's Avatar
Thumbs up
Hmmm, Okay, thanks also Taspeed. I think I'll just open it up and stick it underneath the cowl to check what the clearance is like.
Old Jul 22, 2004 | 02:41 PM
Ferocity02's Avatar
Larry's tool rules! They get those back springs like they are in the front
Old Jul 22, 2004 | 02:54 PM
Inspector12's Avatar
TT-TECH Veteran
Larry's tool works very good. But the one Crane is selling that does both springs at one time is even nicer. Of course it is more than Larry's but cut install in less than half the time. Iv'e used one of the ones you bought and they don't work at all at least not for me! and the $15 NAPA tool works good but you risk the possibility of bending or breaking boltsif you don't buy a hardened steel bolt etc... And of course you will have to cut the handle off for the back cyclinders. Good luck!
Old Jul 22, 2004 | 02:59 PM
Derek98z's Avatar
the Moore tool sucks ***. Spent two hours as well on the #8. Not to mention that the first one I used split in half.
Old Jul 22, 2004 | 07:20 PM
mrr23's Avatar
here's the link to the vinci tool http://www.vincihighperformance.com/...TS%20PAGE.HTML
