Lq9 build safe stroke for boost
LPE, BES, HPR, TSP other select shops can build reliable long stroke LS engines. Usually they don't recommend power adders for the 4, 4+ inch crank set ups. However, it can be done like ddnspider mentioned.
However, no reason in my opinion to stroke an LS motor if you're doing boost. Turbo charged stock stroke 5.3's can make 1,200+ whp for example. Skip the expense of a stroker rotating assembly and spend that on Forced Induction. Just cranking up the boost a little easily makes up for the ~40 less cubes.
Could try a L8T crank, (3.85 stroke) with 6.200 rods and shelf stroker pistons for a middle of the road combination.
