LQ9 piston to valve clearance
Old Feb 14, 2022 | 05:13 PM
Tbaas's Avatar
Default LQ9 piston to valve clearance
Currently building LQ9 have a set of 243 heads was thinking about running Comp 45-469-11 cam
intake duration 281
exhaust duration 247
LSA 113
int. Lift .624
exh. Lift.617
with factory rockers.
I was wondering if I will have issues with piston to valve clearance ?
Old Feb 14, 2022 | 06:47 PM
Are you sure about those duration numbers?? You have WAY more intake duration than exhaust, and that shouldn't be.
Edit- the cam is 54-469-11, and the duration is 281/297, lift is .617/624.
You might edit your post to reflect the correct specs
Old Feb 14, 2022 | 06:55 PM
Tbaas's Avatar
281int/297exh sorry might have got it mixed up
Old Feb 14, 2022 | 07:00 PM
99 Black Bird T/A's Avatar
intake duration 281
LSA 113 int. Lift .624 exh. Lift.617
I can't find #45-469-11 any where.
Could it be 54-469-11 that Richard Holdener runs in practically everything? 231/247 @ .050
What type of piston? Does it have valve reliefs?
6-0l-piston-questions-ls3-heads-w-comp-54-469-11
This may have some helpful information.
Old Feb 14, 2022 | 07:16 PM
Tbaas's Avatar
Yes that’s the one. And it is the factory flat top piston
s. No valve reliefs
Old Feb 14, 2022 | 07:46 PM
It IS 54-469-11
Old Feb 14, 2022 | 08:58 PM
Advertised duration is 281/297
duration @ .050 is 231/247
You will want to check ptv on this setup.
