Another question on cam install.
Old Mar 23, 2003 | 07:03 AM
WU8's Avatar
WU8
Default Another question on cam install.
How big of a hole needs to be drilled in the throttle body? Cam is a TR224 112 on an M6.
Old Mar 23, 2003 | 09:46 AM
AdamSS's Avatar
Default Re: Another question on cam install.
www.ls1howto.com
www.ls1info.com
In one of those writeups they talk about drilling that hole...
Old Mar 24, 2003 | 12:24 AM
Constrictor 98TA's Avatar
Drilling the hole larger in the throttle body blade is not a substitute for getting programming. With a TR224, I would highly recommend getting programming to help with low RPM problems. Then if you want to smoothen out your idle a little bit, you attempt to drill the hole larger. There is no standardized hole size that you need to go with for any cam. To me, its just a band-aid.
