Weird oil pressure issues
I've had it deep in 5k-6k during some Mex races, with no weird issues.
The oil pressure is quick to respond, to RPMs, but when hot, falls on its face, to the point the light will sometimes come on, when at idle.
I had the engine out, to replace the rear main seal, water pump, timing chain, oil pressure sensor, and a bunch of other ****, but forgot to replace the cam thrust plate and didn't bother with the oil pump, because I wasn't having any oil pressure issues, before the pull.
I pulled out the emissions and pvc and now running a catch can, if that matters.
There was no major residue in the pan / old oil and we even cut open oil filter, so I'm guessing that the bearings are okay, I guess. The only thing I can think of, is the pump was on its way out, pickup is clogged (even though we cleaned it), o-ring, and cam plate...
Other than an exhaust leak, hissing at me, at the collectors, the engine is quite, runs smooth and hold a steady 800/RPM at idle. Hardly even lifter tick. So I don't know what is going on now.
Is it possible to replace the oil pump and pick up with the engine in the car?
Also, I have the summit 2 piece timing cover. Will it be a PITA to replace the cam thrust plate?
I have ICT billet mounts. Not sure if that will help or hinder.
02 Trans Am M6
Yeah, but I'm wondering if it moved or ripped when installing the pump.
