OEM rocker arms- which ones?
Old Aug 25, 2022 | 02:01 PM
RJ Squirrel's Avatar
Default OEM rocker arms- which ones?
Hello I am putting together an LS1 (cammed .614/.595) with PRC heads I bought from a builder that did not finish it. I am sticking with stock rockers and deciding which ones I should buy. I have read that the stock LS1 rockers run out of contact patch over .550 lift, and the LS7 rocker arm has a much better contact pattern at higher lift. What I dont know- is the LS7 rocker arm a direct swap in LS1 heads?
Also Rockys offers a GM genuine and also a Melling rocker arm that has snap rings holding it together. Which one is better?
And theres a box of rockers of unknown history that came with it, when bolted down solid with no pushrod they have slight up and down movement, so I am trashing those.
Old Aug 25, 2022 | 02:20 PM
OK discovered LS7 wont work- still digging
Old Aug 25, 2022 | 02:39 PM
You have a Gen III engine with cathedral port heads.
Only one kind of rocker arm ever came on any Gen III or IV cathedral port head, and that is the type you must use, unless you go aftermarket.
Old Aug 25, 2022 | 04:32 PM
Yes I got that, still wondering about the Melling MR 1341 OEM rocker arms, anyone have experience with them?
Old Sep 1, 2022 | 09:41 AM
TurboBuick6's Avatar
.650" lift here on stock rockers around 40K miles, no issues. I must say, my pedestals have been milled to get geometry correct.
Old Sep 1, 2022 | 09:51 AM
SAPPER's Avatar
Stock rockers with a CHE or Smith Bros bushing kit. Skimp on that minor detail and you'll pay for it later...at about 6800rpm!!!
Old Sep 1, 2022 | 12:36 PM
99 Black Bird T/A's Avatar
Ran a 224/224 .581/.581 lift XER cam with stock rockers for 132,000+ miles & 15 years on my old heads & cam set up, no issues. Rev limiter set at 6,800 rpm, normally shifting ~6,400 rpm, hit the limiter several times etc.
I like the OEM spec rockers w/snap rings to retain the needle bearings that WS6 Store sells and used those on my 416. Under ~ .630 lift am OK with a stock tip rocker on the 416.
Have seen a couple of buggered up trunnion installed upgraded stock rockers. They weren't smooth and could feel play. They had Comp's trunnion kit. I would avoid Comp's kit.
Get the CHE kit if doing the trunnion upgrade to stock rocker in my opinion.
Old Sep 4, 2022 | 02:38 PM
01CamaroSSTx's Avatar
If you're having to buy rocker arms anyway why not just purchase a set of roller tipped rocker arms from Texas Speed?
https://www.texas-speed.com/p-7364-t...QaAkB6EALw_wcB
Old Sep 6, 2022 | 10:10 PM
Thanks for all the replies, I wound up rebuilding mine with the BTR trunnion kit that is not supposed to come apart.
Old Sep 7, 2022 | 08:00 AM
gagliano7's Avatar
Boy those are pricey!!
Old Sep 7, 2022 | 08:09 AM
MuhThugga's Avatar
Brian Tooley advertises rocker arms that are supposed to allow for higher lifts. I have no experience with them. Just throwing another option out there.
Old Sep 7, 2022 | 09:55 AM
10-4 to that!
Old Sep 7, 2022 | 02:42 PM
The BTR version definitely looks sturdy.
