Need help with rocker studs
Old Feb 17, 2023 | 07:21 AM
99black315's Avatar
Default Need help with rocker studs
Bought rockers that 3/8 studs are needed to install rockers and can not find 3/8 rocker studs to install into the head. Need help finding them to install into ls 317 heads
Old Feb 17, 2023 | 08:07 AM
Guy with a Chevy's Avatar
They are definitely out there just have to change up the search terms these turned up with "gen 3 rocker studs" add specifics like 3/8th's or metric if applicable
Old Feb 17, 2023 | 10:50 AM
99black315's Avatar
I called arp and spoke with their technical dept and they said that they don't have any "off the shelf" rocker studs for ls heads but they could custom some for me
Old Feb 17, 2023 | 12:13 PM
grinder11's Avatar
I've never seen 3/8" rocker bolts for the LS1, or my LS7. The trunnions have 8mm holes, I believe....
Old Feb 17, 2023 | 12:17 PM
klinznilk's Avatar
ARP 234-7207 is what I used for studs on my LS heads
Old Feb 18, 2023 | 12:26 AM
KCS's Avatar
KCS
Moderator
I think Crane had a kit with rocker studs that were 8mm x 3.8”. Might want to check with them?
