Lq4 Compression ratio help
Old Mar 11, 2023 | 01:31 PM
Lq4c10's Avatar
Default Lq4 Compression ratio help
I’m in the midst of putting together a lq4. I have 799 heads milled 0.020. From what I have heard that would be 10.53:1. Just decided to bore engine over 0.020. Will that bump my compression up much?
Old Mar 11, 2023 | 11:22 PM
Cajun ELESS-ONE's Avatar
Boring will not increase compression. You can go thinner head gaskets to increase it some
Old Mar 12, 2023 | 04:43 AM
LS1Formulation's Avatar
Boring does actually increase compression, just not by much. .020 over on an LQ4 will bump you up by .1, so your 10.53:1 will become 10.63:1, approximately.
Old Mar 12, 2023 | 09:39 AM
Lq4c10's Avatar
Ok, so not much. Thank you
