Weird Oil Pressure?
Old Mar 17, 2023 | 08:45 AM
Blacksix's Avatar
Default Weird Oil Pressure?
Installed a supposedly good LH6 from a seller, changed cam and installed new cam bearings (they were a little worn, not bad) deleted the AFM and installed in a 97 C1500 and shows LOW oil pressure. I do recall using 2 different lifter styles, slightly different oiling holes, didn't think it mattered... Tested with actual gauges, at cold idle with 15w40 it shows 40-45 psi at the front plug and 5-8 psi at the top. Runs great, does have some oil at the rockers. When I installed the Holley knockoff pan I pulled a couple of caps to check the rod bearings and they were perfect with good clearances. 8 original lifters, 8 good used lifters from another build. Once I saw that I did NOT pull any of the mains; I don't like to disturb factory assemblies without cause (may have to change that policy...)
After searching the forum a lot I have changed the filter, changed cam retainer plate (oil gallery plug is in place), and plugged the AFM towers. The original barbell is in place, I haven't touched it. I can't pull the pan with the engine in the truck.
Is there anything else I can check before pulling the engine? I suspect main/thrust bearings now but wanted to exhaust all the options first. I was SURE it was either the cam plate or the AFM towers but alas...
Old Mar 17, 2023 | 05:30 PM
01CamaroSSTx's Avatar
New or used oil pump and did you check the pressure relief valve? What about the o-ring for the pickup tube?
Old Mar 18, 2023 | 10:42 AM
Blacksix's Avatar
New pump, replaced due to AFM. Didn't check the valve. 45 psi at the front port means the pump end is OK, no?
Old Mar 18, 2023 | 11:13 AM
LS299S10's Avatar
What AFM delete plate are you using?
Old Mar 18, 2023 | 11:31 AM
Blacksix's Avatar
Amazon plate, along with tower plugs from LSXleration
Old Mar 18, 2023 | 11:33 AM
LS299S10's Avatar
Is there an o-ring for the oil pressure sender between the plate and block?
Old Mar 18, 2023 | 11:49 AM
Blacksix's Avatar
Pretty sure
Old Mar 18, 2023 | 12:12 PM
LS299S10's Avatar
Are you reading the top pressure with the mechanical gauge?
Old Mar 18, 2023 | 12:22 PM
Blacksix's Avatar
2 mechanical gauges
Old Mar 18, 2023 | 01:12 PM
RB04Av's Avatar
Sounds kinda like maybe the oil cooler line blockoff thing is ... blocked off.
Old Mar 19, 2023 | 12:13 PM
Blacksix's Avatar
Pulled that blockoff and blew out the passage from the top down, seemed clear. Put the blockoff back on and, on a lark, blew air into the top gauge port (I have a 2ft hose on it.) Air blows directly out of the oil filler at full speed. So, pressure in the oil passages bleeds directly back into the crankcase, that's where all the oil pressure is going. Now just to figure out where...
Who has any thoughts? Valley cover gauge port O-ring missing completely as posted above? I'm pretty sure it was in there and it's a lot of work to check. What kind of leak would be that big? I thought maybe the barbell seal or something but I would think that would be a slower hiss.
Old Mar 19, 2023 | 12:31 PM
RonSSNova's Avatar
Is the pan from the original engine? I recall a pressure relief thing inside the pan. Was never sure what it was.
Pan was from a 2010 Camaro, didn’t fit my car.
Just a thought.
Old Mar 19, 2023 | 12:35 PM
Blacksix's Avatar
Holley knockoff pan. I'm pretty sure they have no relief valve
Old Mar 19, 2023 | 12:48 PM
LS299S10's Avatar
Blowing air into the top port will eventually lead back to the pump and exit the pickup tube. Every bearing will be a very small leak along the way.
I run a Holley knock off pan, it uses no bypass but it recommends the pf63 or pf48 or similar filter and they have an internal bypass.
Old Mar 19, 2023 | 02:02 PM
Blacksix's Avatar
The filter should have an anti-drainback valve, so air/oil pressure applied in reverse should stop at the filter, no?
In any case, the air comes out of the filler tube with pretty much no restriction at all, it's a single giant leak.
Old Mar 19, 2023 | 05:23 PM
LS299S10's Avatar
I was just thinking about what I thought would happen.
So I went out and tested it. This is on a perfectly good running 5.3 that was removed for a 370. It had very good oil pressure. I put the stock pan back on it to keep it closed up.
I had to remove the timing cover to get to the second bolt of the holley knock off oil pickup tube so I taped the front seal up for this test. It is a gen 4 oil pan but the internal relief valve is removed and plugged. Because I did run it with this pan before the swap pan.
Putting air into the top oil hole makes it come out the dipstick tube. Even with the valve cover tubes wide open.
Old Mar 19, 2023 | 07:50 PM
Blacksix's Avatar
Interesting. That much air comes out the lifters, rockers and bearings? I would have thought less, but maybe it makes sense. In any case, the air coming out of the 1.5" filler hole was enough to feel on your face.
Old Mar 24, 2023 | 08:50 AM
Blacksix's Avatar
Any other thoughts on how oil pressure can be lost between the the filter and the top end? Leaky barbell seal? It'd have to be pouring out of there. Or, are the mains actually bad? Grasping at all straws here before pulling the motor.
Old Jun 14, 2023 | 08:23 AM
Blacksix's Avatar
So I've removed the pan and double-checked the o-ring, it was perfect but put in a new one. While I was in there I rechecked a couple of bearings, they're fine with around 0.0015 clearance. Removed the transmission, replaced the barbell and rear cover gasket, still have 5psi oil pressure.
Everything has now been checked from pump back to pan: o-ring, tried different filters, barbell, rear cover seal, no screen at the gauge, AFM tower blockoffs, cam retainer plate, front plug in place, bearing clearances OK. What could possibly be left? The lifters are a mix of used lifters that I checked for operation and made sure they slid nice in the bores. Is there any chance of losing oil pressure from bad lifters? I don't see how.
Old Jun 14, 2023 | 11:48 AM
LS299S10's Avatar
Did you see the oil pressure when you got the engine and before you opened it up?
Maybe it's a cam bearing problem. Did you tear it down to the bare block to change the cam bearings?
