Pushrod length question
Old Mar 22, 2023 | 09:18 PM
Rx7TyreBurna's Avatar
Default Pushrod length question
Lifters are LS7 lifters. The bulk ones that used to be on WS6store.
Now, I previously had 7.375 pushrods, before all the rebuild stuff. Now, the engine runs, seems to pull well, but there is kind of a ticking / sewing machine sound and it annoys me a lot.
I decided to attempt to measure the pushrod length while it has normal dual springs in it. I can't get my fingers in to turn it while it's in. But, 9 turns is too loose, and 10 turns is too tight. So, this would be between 7.25 and 7.3, right? at 7.25, there is a little, motion, not much. at 7.3, it's preloading a little. So, 'between', I could say 7.275 or so.
Now... i have 7.375 in there. That would give me around .1" preload, right?
When I tighten / torque down the rocker with the 7.375 rod, I see the valve spring compress some.
I took a dial gauge and setup to look at retainer height. I tighten down the rocker, and see it compress, dial gauge spins about 1.5x. Then, if I watch it, it slowly spins back to the original spot, but it takes ~30-40 seconds to get back to the original spot.
Does this seem normal? And, is the .1" preload too much? Feeling kind of like grabbing 7.35 rods... ?
Old Mar 23, 2023 | 10:08 AM
jetech's Avatar
Veteran: Air Force
If I am understanding your post correctly... sounds like the pushrods are slightly too long
Old Mar 24, 2023 | 11:14 AM
Thanks, Yeah, I suspect they're a little too long. Going to order some 7.35 length rods.
Old Mar 24, 2023 | 01:52 PM
jetech's Avatar
Veteran: Air Force
Read this article I would measure at least an intake and exhaust length on both banks. When I did my setup I measured all positions, but the engine was on a stand...way easier. If you are having trouble reaching in to spin the checker to make it longer, take the rocker off and adjust the length of the checker, re-install rocker etc... takes longer but you'll get it right. Scoggin-Dickey video
