BTR vs Howards Cams
I have an '02 Trans Am w/ the LS1 Automatic with about 67k miles that I purchased a couple of months ago. The engine is completely stock currently and I'm looking to add a little bit more power. I'm looking at doing a cam, valve springs, headers swap and an ECM retune once installed. From what I've read on various forums, BTR (Brian Tooley Racing) is what a lot of guys go with using their stage 2 or 3 cam. Although recently when I looked the stage 2 cam up it has been discontinued and BTR is using their Red Hot cam as a replacement but it doesn't give specs. I've had good experience with Howard's Cams in the past with flat tappets so I gave them a call today to see what they have and the contact that I spoke with recommended their LS1 cam #190385-12. Howards' recommendation seems to be a middle ground between the others.
I would be using this car for a daily driver, so I'm looking for good street manners. What do you guys think or what alternatives have you used?
Link to the Howard's Cam (190385-12): https://www.howardscams.com/hydrauli...cams-190385-12
Link to BTR stage 2 (now discontinued): https://briantooleyracing.com/btr-ca...-32734133.html
Link to the BTR Red Hot (stage 2 replacement): https://briantooleyracing.com/btr-red-hot-camshaft.html
Link to BTR Stage 3: https://briantooleyracing.com/btr-ca...-33142123.html
It's very strange to me that they have discontinued their stage 2 LS1 cam and are telling people to go with their Red Hot cam though. If you're worried about the driveability of the stage 3 cam, then consider the Cam Motion Titan 4 cam.
The BTR stage 3 will have the strongest midrange-top end, partially because it has the most overlap (12.5*). I would rev that cam to 7000 RPM or so. However it won't drive as smoothly as the Titan 4 cam which only has 4.5* of overlap.
