No coil pack bracket on ls1
Old May 14, 2023 | 11:28 AM
Mowen4571's Avatar
Default No coil pack bracket on ls1
I went to change my spark plugs on my ls1 4th gen camaro and noticed there is no coil pack bracket on either valve cover. How would I go about removing the coil packs? I just need to remove them from the passenger side to get access to the spark plugs. I’m having some trouble finding any information on this and I’m assuming the previous owner removed the brackets for some reason. Any help is appreciated thank you.
Old May 14, 2023 | 11:44 AM
dixiebandit69's Avatar
Um, unbolt the coil packs and remove them?
Am I missing something here?
Old May 14, 2023 | 12:07 PM
01CamaroSSTx's Avatar
LOL...Sounds like they've been removed from the factory bracket and are now bolted directly to an aftermarket valve cover. If this is the case then they will unbolt individually.
Old May 14, 2023 | 02:34 PM
The plugs are below the coil packs enough so the plugs should come out without removing the coils.
Old May 14, 2023 | 06:20 PM
Yeah, my first thought also. Must be more here that I’m missing.
