LM7 5.3 help
Old Aug 4, 2023 | 09:30 AM
DrMick's Avatar
Default LM7 5.3 help
I have measured my bores and the largest is 3.783 with 3.780 being stock spec. Can I hone and rebuild with stock pistons and rings or do I require bore with larger rings and pistons?
Old Aug 4, 2023 | 11:21 AM
stockA4's Avatar
5.3's typically wear the piston skirts. New pistons and rings should be fine. If you've never honed a cylinder before you may just want to leave it alone. Post some pics of cylinders and old pistons if you want. I've had good results Just putting new pistons, rings, and oil pump if everything else looks good
Old Aug 4, 2023 | 05:35 PM
DrMick's Avatar
Thank you! I think Im good too.
Is there reference you know for what tolerances are?
Old Aug 14, 2023 | 03:57 AM
AndrewThompson's Avatar
Have you found any references?
Edit: ok
Old Aug 14, 2023 | 04:51 PM
DrMick's Avatar
Not yet
