ls1 to ls3 gen 3 to 4
Is this all that would be needed to fit an ls3 or gen 4 in an ls1 plate f-body,etc?
Lingenfelter TRG-002 LSX Engine 58X To 24X Trigger Wheel Conv Control Module Kit
2006-2009 Corvette LS7 engine or a 2008-2009 Corvette LS3 engine in a 1997-2004 Corvette or a 1998-2002 Camaro or Firebird.
The other idea would be to simply build a iron 6.0 gen 3 and fit ls3 heads on it for fairly cheap. Just curious i have a 2004 GTO ls1 cable driven but am curious about fitting a ls3 head style setup.
LS3 in a Trans Am Post 2
You fit one in an f-body an ls3 or 6.0 ls3 heads? Is the engine any wider or take up more space. Have any photos? The iron 6.0, ls3 head, tunnel ram or stock ls3 intake maybe an easier cheaper idea without all that extra stuff but is a bit heavier an aluminum looks nice.
Was it a stock ls3? Could you tell any big difference in power from direct swap maybe 100+hp more?
Mines a 2004 gto ls1 cable driven just before the 05 had an ls2 drive by wire which you could put ls3 heads on.
The trigger box does add a slight delay on crank, to sync up, but otherwise it runs fine with the LS1 PCM
I had a LS7 in my Fbody with the Lingenfelter conversion box. Even though there is a slight delay it was barely noticeable on my car. I won’t be reusing the conversion box and will be selling it if interested OP. It has very little miles/hours on it.
