600rwhp
Old Aug 22, 2023 | 12:10 PM
cmv's Avatar
cmv
Default 600rwhp
Im currently building a lq9 and i have it bored over to a 6.2 with a stage 2 ls3 cam ( 225/238 .620"/.605" 113+3 ) forged pistons, rods, & crank and i have a p1sc1 procharger is it possible for me to make around 600-650rwhp if so how many lbs do i need to consider to make my goal???
any recommendations are appreciated
Old Aug 22, 2023 | 08:10 PM
RB04Av's Avatar
How many lbs will it give?
If that's not enough, find some more lbs somewhere.
Old Aug 22, 2023 | 10:12 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Depending on compression and fuel I would spitball 6-8 lbs.
Trans & stall if auto also play a role.
Old Aug 23, 2023 | 12:07 PM
klinznilk's Avatar
I made 585 rwhp on SBE LS1, stock heads (minus cam support stuff), cam. ls6 intake, LT headers no cats and catback
I was 10ish pounds of boost on d1x
Old Aug 24, 2023 | 04:41 AM
Jimbo1367's Avatar
Does anyone have first hand knowledge of how much HP you could boost a .065-.070 6L block? Would a gen IV block hold any more power with such a over bore and boost?
thanks
Old Aug 24, 2023 | 05:43 PM
Utinator's Avatar
thanks
I don't have first hand knowledge of boost in a block bored that far over. I have talked to my local machine shops about it before though. They normally don't recommend boost when boring more than .030" on an iron block, or .005" on most aluminum blocks. You could probably safely run 6-8lbs of boost on an iron block bored .065" over, but it's not generally recommended. Any more boost than that on a max-bored block and you are asking for trouble.
