comp cam base circle
Does anyone know the base circle and pushrods need? Can use stock but will probably get the sowing machine sound. Want to keep the right geometry for the rockers. Have stock heads, not milled.
Thanks for the help.
Why have a help line if they can't help????? Base circle info shouldn't be that hard or pushrods for that matter.
you could reuse your stock ones as this cam is not aggressive enough to really warrant hardened ones.
it's up to you.
