BTR Red Hot Cam Camshaft - Who has one?
how long are your pushrods? Put longer ones in there dude it will quiet down if it's not a bad lifter. 5w40 is better than 5w30 for a performance build as well IMO
7.450" length pushrods should be the minimum with stock unmilled heads and any aftermarket cam you use IMO you can't hurt anything with more lifter preload but you certainly will if you don't have enough to keep things quiet.
There's nothing wrong with btr stuff, Comp, or anyone else's really, it all comes down to the quality of the lifter preload and the oil you use.
I got to worrying about the trunnions in the rockers and whether or not I had a bunch of needle bearings running around my motor. When I pulled the VCs everything was looking and feeling fine. No outrageous lash going on. I'm ok with the cam and will run the car until it breaks, or doesn't. I don't think it will, I just am not used to this kind of thing being schooled in Gen 1 small blocks not LS stuff.
If you have 7.400 pushrods I guarantee 7.450" will make it better
I use 5w30 royal purple synthetic in my all original 2001 LS1 and I use 5w40 Castrol synthetic in my homemade iron 6.2L build these oils hold up better for me running the engine hard repeatedly and don't need changed as often. I will say that the royal purple is seeps into the metal like nothing else and it will often cause the minor seepage at the oil pan gasket on older engines just snug up the pan bolts if it does that to you but it's totally worth it the engines love it
I replaced the oil with 5W50 Mobil 1 standard grey box synthetic and It was the smartest choice I've made all summer, Even in this horrible heat, the pressure Is back a little higher than it was before actually and my melling 295 pegs the 80 PSI gauge when you rip it out, It's already above 60 PSI past 4K now. And it's running cooler I don't even hear the fans as often driving around in this heat. I'm really, really impressed. My build tolerances aren't super loose and so the 5w is still important for Flow when the engine warms up and the 50w It's just feels so much better there's power in the oil for sure logs don't lie
