Rear Crank Sleeve?
Old Mar 9, 2024 | 03:26 PM
Lxjoshxl's Avatar
Default Rear Crank Sleeve?
Machine shop polished up crank and said there’s a groove in the back of it where the rear main seal goes. Is there a sleeve kit for it like the old sbc and had anyone used it with good results? Also if so what’s the part number for it and can I use my regular mahle rear main gasket set with it. Thanks-Josh
Old Mar 9, 2024 | 04:24 PM
LS1 TJ's Avatar
Can it be welded up and then re-machined?
Old Mar 9, 2024 | 04:37 PM
Lxjoshxl's Avatar
I could ask seems like if they do make a sleeve easier option?
Old Mar 10, 2024 | 04:52 PM
Lxjoshxl's Avatar
Machine shop said a sleeve would be easier. Surprised this isn’t a more common issue? Maybe because of the mileage or he is worried about something that might not become a leak
Old Mar 10, 2024 | 05:12 PM
Rich-L79's Avatar
What kind of a machine shop are you dealing with? If there is a sleeve option I would think a machine shop would be the first to know about it.
Old Mar 10, 2024 | 11:41 PM
dixiebandit69's Avatar
FelPro makes a couple of repair seals, but they all require machining.
FEL-PRO 16228
FEL-PRO 16229
Old Mar 11, 2024 | 08:17 PM
I can guarantee you that you can find a good used crank cheaper than that repair. As far as balancing goes, I guess I’m the last guy around balancing an assembly, so just throw it in and go. That’s what most folks here advise others to do…lol.
