Solid dowel pins vs. Split dowel pins
Old Mar 28, 2024 | 08:36 AM
66OldsLS's Avatar
Default Solid dowel pins vs. Split dowel pins
I recently got my parts in from Michigan motorsports and was just wondering are solid dowel pins okay to use instead of the factory style split dowel pins? do they affect clearance or alignment? Should I re-use the factory style split dowel pins? I am studding my 07' LQ4 LS motor with ARP head studs and was wondering if this mattered at all. thank you.
Solid dowel pins:
​​​​​​https://www.michiganmotorsports.com/...7-6-0-6-2-7-0/
ARP head studs:
https://www.michiganmotorsports.com/...6-l77-ly6-l96/
Old Mar 28, 2024 | 10:10 AM
Unless your gonna turn 8k+ rpm, for an extended timeframe…think endurance build… you’ll not notice any difference. Boost pushes heads upward…rpm moves heads laterally. Nothing wrong with going solid at all.
Old Mar 28, 2024 | 12:01 PM
66OldsLS's Avatar
Okay, thank you!
