11:1 compression nitrous 5.3!
Old Mar 31, 2024 | 05:56 AM
21cwhitfield's Avatar
Default 11:1 compression nitrous 5.3!
Well so far I have a 5.3 lm7 bored .030 over with a BTR N/A stage 3 camshaft, Fast LSXR intake manifold, 42lbs injectors, a summit 3.810 piston and rod kit, with a set of PRC 225 as cast heads. I’m looking at a 11:1 compression and was thinking I’d make somewhere about 450-480 WHP… I’d like to hit it with nitrous, but how much? Is it safe? What is safe? Some told me through a Facebook group I can throw a 200-300 shot safely others said go turbo. What are you guys opinions on this? Thank you in advance.
Old Mar 31, 2024 | 03:00 PM
You can throw a LOT of N20 at these LS engines IF the tune is right. Make sure you know a great tuner with nitrous experience before you commit, or you’ll melt it down quick. They will hold it. Since your already at 11:1 comp, I’d lean toward nitrous if it were mine.
Old Apr 1, 2024 | 06:50 AM
LS1Formulation's Avatar
I have that exact same piston/rod combo, .030 over as well, but my compression calculation was only 10.5:1 with a 62 CC chamber and a .055 gasket utilizing a 3.950 gasket bore. Just curious what specs you used to obtain an 11:1 compression calculation. Are you having the heads milled?
Old Apr 11, 2024 | 01:22 AM
MadisonReid's Avatar
Good work buddy.
Old Apr 12, 2024 | 09:08 AM
Bspeck82's Avatar
Be sure to run 100+ octane and start with a 2 degree retard per 50hp.
