Fuel maps - LQ4 6.0 + E1840P
Hello forum,
I'm in my first cam swap and a bit lost on how to start tuning the fuel map. Anyone running the same (or similar) setup could share the fuel maps on the forum? My setup is LQ4 6.0, 862 heads, E1840P (Sloppy Stage 2), TBSS intake, BRP Hotrod long tube headers 1-7/8 primaries, and manual transmission using the original GM computer. I just finished the engine refresh and dropped the cam in. I'm replacing the injector with a set of FFV injectors and made the flow adjustments on the respective section on the file already.
I figured I can dial-in the original map slowly but given its my first ever cam swap I would like to take a peek from a map that someone already tuned and look for the differences and maybe go from there (I know its not a plug and play situation).
Thanks in advance.
Thanks in advance.
