Uneven deck height side to side?
Old Jun 19, 2024 | 09:13 PM
NovaKeagan's Avatar
Default Uneven deck height side to side?
Just got my L33 block resurfaced, the machine shop took .0006 of one side and .0002 on the other side? Can I get away with this? I gotta call him and ask if the heights are even now but if not, am I fucked?
Old Jun 20, 2024 | 07:33 AM
KCS's Avatar
KCS
Moderator
That’s weird, usually a machinist would cut them the same. You may need to check to see how far the pistons are above the deck of the block at top dead center. One being cut .002” and the other .006” isn’t really a big deal, but I would talk to the machine shop and ask why they did that.
Old Jun 24, 2024 | 10:30 PM
1FastBrick's Avatar
It could be how the block was originally cut. It may have have needed more material removed from one side of the block to bring both decks to the same height from the crank centerline.
Old Jun 25, 2024 | 07:05 AM
TrendSetter's Avatar
if you typed that correctly, (0.0006, 0.0002) thats less than half a thousandth difference. most people at home cant even measure that.
Old Jun 25, 2024 | 07:36 AM
Old Buzzard's Avatar
How much was cut could be due to what you told them to begin with...
1. Clean it up.
2. Correct the deck height.
Old Jun 25, 2024 | 08:31 PM
It’s not terribly uncommon to cut a block differently per side to square deck it, if the shop knows how to read deck height. But as mentioned above .0002 & .0006 isn’t much material at all…
Old Jun 25, 2024 | 09:03 PM
RB04Av's Avatar
What matters is how even the block is now, and how accurate the crank centerline to deck surface measurement is, and how even it is front to rear. What they had to cut to get it there, is irrelevant.
