Any reliable LS roller rockers?
Old Jul 30, 2024 | 06:58 AM
klinznilk's Avatar
Originally Posted by Fireballmatt15
Do your PRC's have bronze guides, that's my worry that the geometry may be different than the YT's causing premature guide wear. Also do they fit under the stock valve covers? I do like the idea of a steel roller rocker over an aluminum rocker, in my mind that would be stronger. Have you had any issues with valve float with the heavier rocker?
Mine do have the bronze guides
Ran them with STOCK valve covers for a while however I did change up to Holleys taller valve covers with coil mounts awhile back.
Old Aug 2, 2024 | 10:42 PM
Fireballmatt15's Avatar
More than likely going to go with the tsp steel rollers as I want something that is durable and I think the steel rockers would outlast the aluminum rockers. I talked to Texas speed and they said that there was minimal to no difference in weight vs OEM on the valve when using a titanium retainer and their rockers. Gonna mill the locating tabs off my oem pedestals and use the Texas speeds with CHE bushings.
