High oil pressure
So many possibilities...start with replacing sensor with a mechanical one to rule out something electrical. If still the same then you know it's internal and likely the oil pump. If not, test the sensor with a meter and either replace or look for a bad ground. This is the path I would take before I start dropping the oil pan and removing front accessories to replace the pump on a hunch.
