02 TA LS1 5.7 swap options
Old Sep 8, 2024 | 11:25 PM
gbgn1's Avatar
Default 02 TA LS1 5.7 swap options
Trying to help someone who broke their ls1 block. Car: 2002 TA 5.7.
What is all involved with a truck 5.3 or a 6.0 swap of the same year? what would be best? straight forward?
He is almost 70 years old and just wants to get his pride and joy back on the road. Used ls1 are crazy expensive and can't find anything with low miles
Thanks
Old Sep 8, 2024 | 11:35 PM
gbgn1's Avatar
If the Adm wants to move this thread Thats just fine. Just noticed in the wrong thread
Old Sep 15, 2024 | 05:44 PM
1bdbrd's Avatar
If using the same year engine then it's pretty straight forward. The truck blocks I think need a hole drilled for one of the accessory bolts and then need to swap the intake as well as the oil pan, pickup and windage tray from his current engine. Use everything from his stock engine and it should be pretty easy.
If the car is a 6 speed then it will also need a pilot bearing installed in the crank as well.
