LM7 build, first LS swap attempt.
Maybe just a TBSS (Trailblazer SS) intake manifold, a set of 243 heads with a bowl blend and multiangle valve job, and a good cam plus a decent exhaust will get you where you want. Won't cost much either compared to more sophisticated setups.
Or you could just find a good single turbo setup. But then you might need to gap the rings....
