what sorta compression did i end up with
Old Oct 17, 2024 | 09:01 AM
learning101's Avatar
Default what sorta compression did i end up with
ok new rebuild too my 2002 avalanche with a 5.3 stock motor. and replaced the dish pistons with flat tops and swapped out heads to the 799 heads and took 30 thousands off the head . im running the Cam Specs: 212/218, .553/.553 did i loose compression or gain. and hors power any idea guys it seems ti idle a little rough but i have not gotthe computer programed yet
Old Oct 17, 2024 | 09:09 AM
madmike9396's Avatar
This should give you a rough idea of what compression is.
Compression Calculator (summitracing.com)
Old Oct 17, 2024 | 09:34 AM
yea ive looked at that chart and a shade tree mechanic as i em some of the numbers i dont know
Old Oct 17, 2024 | 11:47 AM
low2001gmc's Avatar
MASS seller approved
5.3s with flat tops and 243/799s are 10:1 and with milling 30, you are now around 10.5 with stock head gaskets.
Old Oct 19, 2024 | 08:46 AM
PenelopeHill's Avatar
Spoiler!
Thanks for the link, you made my day.
