Cam upgrade
The top end will flow plenty. All you're doing with changing the camshaft is sacrificing a bunch of low and mid-range for a little more top end. Even the JYD, which is mildly bigger than what you have now (with a lot more exhaust duration) carries to 7k before it peaks in a 6.0L. Those bigger cams you might gain 10hp after 6k+rpm. But you'll give up a bunch below that. So if you decide not to stay with the stroker, I'd go withe JYD for that reason.
if you wanted to go smaller, also consider the 8710 from summit like was recommended, but honestly at 230/242, it's not going to be drastically different than the ss ht you have. Ss ht is better down low and the 8710 would be better on the top end.
I might be interested in buying your ss ht if it's in good shape when you pull it. Let me know.
Nvm i read the whole thread again. Use either the btr or tsp cam you already have. they are both solid and decent sized.
You might go with a smaller head. That 230 head is real designed for a 4.00 bore or bigger. It fits a 3.900 bore, but not ideal TBH, your TSP 2.5 heads are probably plenty. I would focus on the valvetrain/intake manifold go from there.
FYI, a lot of brain trust has left the building here. Your combo is nothing new, start searching old threads and you'll find more info there than anyone now can really contribute. Sad, but I see it here more and more
