5.3 L33 Autocross Build
LS6 intake with stock LS6 injectors
LS1/LS6 BTR stage 3 NA Cam kit (Includes their platinum .660 Duel spring kit)
BTR Delphi lifters
Upgraded one-piece pushrods (Unsure of what to get yet until I check with the other new components)
Comp Cams Pro Magnum LS1/LS6 Roller Rocker Arms (The ratio increases from the stock 1:7:1 to 1:8:1 I'm unsure of how much this affects and would like to know if I will need specific pushrods because of it. I plan on using a pushrod checker before buying my pushrods)
A stock L33 with a gen 4 truck intake and a 222/225 cam made 426 horsepower at the crank on the engine dyno.
-Stock rockers are more than enough for 98% of all setups.
-The L33 comes stock with the same lifters you're looking to buy.
-Pushrods aren't always necessary, they're somewhat setup dependent. I've been 7600 RPM on stock pushrods.
