Guys with the TR 230/224.
Old Mar 24, 2003 | 06:38 AM
CamSS00's Avatar
Default Guys with the TR 230/224.
I put the cam in set at 0 thinking it had 4 degrees of advanced timing in. A buddy of mine told me that they don't and that I had to set it myself. I just want to know cause I'm going to be changing the oil pump here soon. Thanks
Old Mar 24, 2003 | 06:42 AM
HITMANSS's Avatar
Default Re: Guys with the TR 230/224.
Didn't the cam come w/ a spec sheet or card? It may also be stamped onto the end of the cam.
If there's no way to tell for sure, you can always use a degree wheel, & check when the intake valve opens.
Good luck....
<small>[ March 24, 2003, 06:44 AM: Message edited by: HITMANSS ]</small>
Old Mar 24, 2003 | 06:58 AM
jfm's Avatar
jfm
Or,call Thunder,they are GREAT with tech support.
Old Mar 24, 2003 | 07:28 AM
CamSS00's Avatar
I already have the cam in and have been running. Seems ok to me. I just want to see. I think I'm going to degree so I can get it right.
Old Mar 24, 2003 | 07:54 AM
PurEvl's Avatar
unless specified otherwise it has 0 ground in I believe
Old Mar 24, 2003 | 09:11 AM
Paul F's Avatar
The TR230/224 has 0 advance ground into it. That's the way we designed it and the way we install it. So dot to dot should be fine.
Old Mar 24, 2003 | 10:28 AM
CamSS00's Avatar
Thanks Paul. I was going to go out and get a degree wheel. I have mine set dot to dot. Thanks
again.
230, cat, d, tr
