Lifter preload
Old Dec 1, 2024 | 04:57 PM
sewerpickle's Avatar
Default Lifter preload
So, I've never really messed with stock LS stuff, but have a cam only 5.3 in a cruiser. Did a new timing set, elgin ss2 cam, elgin lifters, new trays, gaskets and so on. Using a 7.400 pushrod, and 22 ft/lb on the stock rockers I get 1.25 turns on the rocker bolt. I have some valvetrain chatter though. Is the number of turns albeit a "sloppy" way of doing it showing I need more preload?
None of my valvetrain tools are tools are at my shop right now.
Old Dec 1, 2024 | 05:05 PM
the_merv's Avatar
Veteran: Air Force
The only number of turns I've ever counted is with the Pushrod Measurement Tool, and that's the only way I'd do it.
Old Dec 1, 2024 | 05:15 PM
I get that, and have never done it without the proper measurements, just don't have my pushrod tool here at the moment.
Old Dec 2, 2024 | 02:35 PM
Jake Wade's Avatar
1 1/4 turns should put you pretty much in the middle of the lifter plunger travel, assuming you are using GM lifters.
Old Dec 2, 2024 | 03:12 PM
Lifters are Elgin 2148-S.
Old Dec 11, 2024 | 12:27 AM
JillGarcia's Avatar
Hello, everyone. How is everything going?
Old Dec 11, 2024 | 06:26 AM
Sweet first post.
Old Dec 11, 2024 | 07:41 AM
01CamaroSSTx's Avatar
Using a pushrod length checking tool with the rocker arm set to zero lash and the cam lobe on the base circle of the camshaft is how you should determine pushrod length.
• .050" stock lash
• .070" - .100" performance
• .120" - .150" total travel
So I'd be shooting for .070" preload on those.
 Michael S. Palmer
