Will 99 heads go on a 98 block??
Old Jul 28, 2004 | 12:15 AM
Zach@Texas-Speed's Avatar
Default Will 99 heads go on a 98 block??
will 99 heads go on a 98 block since the 98's have perimeter bolt heads
Old Jul 28, 2004 | 01:38 AM
goober35's Avatar
yes. But you will have to buy new valve covers and the brackets for the coil packs to mount.
Old Jul 28, 2004 | 03:02 AM
jrp's Avatar
jrp
SN95 Director
i picked up my centerbolt valvecovers and coil pack brackets off of ebay.
Old Jul 30, 2004 | 09:54 AM
OWENMUSTANG's Avatar
New GM stuff is'nt that bad if you can't find used.
list for the brkts is 14.42 ea
list for the cvrs are 62.11 & 105.60
+ gskts & bolts
of course, you don't pay list....
Old Jul 30, 2004 | 12:16 PM
Another_User's Avatar
Does a bear poop in the woods? Of course you can use the later model heads. But they flow the same, so if you are in the market for some heads check out Patriots stuff. The 98 heads are cheaper if I recall correctly. It's not like the different valve covers cause major oil leakage or anything.
