LQ4 truck build
Seriously, a lot of these trucks routinely go 300k+ WITH a landscape or construction trailer behind them 100% of the time. My mason has one and I don't even know how many miles he's got on it. I don't think I've ever seen his truck without the trailer behind it.
I've bought an 06 Suburban LQ4 2500 a few years ago with 225k. It's now got 265k and original drivetrain as far as I can tell. Last spring it had developed an intermittent lifter tick, so I pulled the engine to do a freshen up. Bearings and cylinder walls looked really good. New bearings, new lifters, light cylinder hone and piston rings and it's back in action. I went with the Summit 8718R1 cam and I really like it.
With 75k, I would absolutely not even mess with the transmission. Just do a fluid change. If look around here, the Transgo kit is not even something the transmission performance builders recommend...Cam and headers and let her rip.
Even my stock L31 350 responded like I was spraying it with a small shot of nitrous on 91 with a good tune. That one went from 185 whp and 250 wtq on the stock tune on 87 to 257whp and 330 wtq with tri-y headers and a good tune on 91. It made 229 whp and 304 wtq tune only.
honestly big truck torqunator or btr truck Norris will give you more power and torque and be amazing. Even with the cam I have the torque gains start right at 2500rpm which is the factory convertor stall (2600rpm ish)
I'm running 10.6:1 comp after calculations and softening the heads slightly. I also coated everything with a ceramic heat coat to prevent heat soak on the chamber and Piston.
you could probably get away with 10.1 (799 heads on lq4 dished pistons) with 87 but it will pull timing when towing, but a little 93 and you'll probably pull nothing when towing.
I was worried about comp ratio but the guy I bought heads of off had a 10.7:1 truck running 87 although a lighter 1500
if your looking for more torque in cruising rpm of 1800-3000rpm you'll want a smaller cam and I'd probably go the Summit route to save money. the truck Norris gains are a bit higher. also realize the summit cams can be noisy because they are really getting all the power they can and have quite aggressive lobes which will help hold power longer and also alow it lower.
you would need your own copy of HP tuners to change tunes all the time best bet, set up the tow haul mode good to keep the engine reved up a little which will lessen the effect the trailer has. if your tunned well with good low and high spark tables knock learning may be able to adjust well enough for towing. realize that even factory these trucks pull a ton of timing 87 without a trailer from the logs I had taken on the stock motor
