help im missing something about push rods
Chances are, sitting there with valve spring pressure on them, they'll bleed down overnight or whatever, if you're not gonna crank it right up immediately anyway.
Regardless, it's a total non-issue. Happens to everybody every time with every motor of every kind from every mfr. If it was a genuine problem you'd be hearing AHELLUVALOT more talk about it everywhere.
1. Why do you think the current pushrods are too long…is it because of a ticking noise, or does the truck do something weird when running?
2. What lifter did you use…is it an LS7 variant, meaning you bought simple replacement lifters?
Camaro,Trans Am,GTO,G8,Corvette,GM Truck,CTSV,Silverado,Sierra,4.8,5.3,5.7,6.0,6.2,TB SS,Chevy SS,LS1,LS2,LS3,LS6,LS7,LS9,LQ4,LQ9,L33
Lifters OEM:12499225
Guides Trays OEM:12595365
On my engine (04 LM7) there's a little rectangular cast-in "feature" on the underside of the stand thing that sort of locates it on the bosses of the heads. The bosses aren't square, so if the stand is put on turned the wrong way, the "feature" holds the stand up off the boss so that it won't sit down flat on the heads.
Guess how I know this.
I have no clue whether ALL of these engines include this feature, butt it's DEFINITELY possible to install those things incorrectly on at least SOME.
