Pushrod length?
On a stock block and crank, (2002 4.8 vortec) Stock aluminum heads, What size pushrods do i need? I found a set of 7.4 inch on FB with rocker arms includes, Will these work?
The springs with the kit dont matter i have some coming alongside the cam. Just wondering about the rods and rockers
FB DESCRIPTION:Ls Stock rockers, 7.4" chromoly pushrods, Summit Racing Beehive Springs. 130 lb. Seat pressure 1.290 o.d., handle up to .650 lift. Just broke in. Came out of my 5.3 gm vortec. Always maintained with no hard driving and properly broke in. The Beehive are best for harmonics so the springs won't "dance" on you. I believe 06-13 4.8, 5.3, 6.0, and 6.2
Thanks guys! im new to forums and LS engines but ive been watching for a little while.
I thought he asked what size he needed. Which is why I quoted that.
As far as length, he needs exactly the same length as everyone else needs: whatever length that he sets his adjustable push rod to that exactly takes up all the end play without depressing the lifter plunger at all, plus his desired preload.
