Timing chain position inspection
Old Mar 3, 2025 | 12:20 PM
Weathers5's Avatar
Default Timing chain position inspection
Is there any way to check timing chain position without removing the timing cover?
Old Mar 3, 2025 | 01:11 PM
Not_usually_UK's Avatar
Presume you’re worried about condition, if so not really, you could check backlash in chain by turning crank and watching cam movements , but not very effective & it does not tell you condition of gears.
If are meaning the cam timing, then it would be valve lift closing at crank angle with dial gauge.
Old Mar 3, 2025 | 01:24 PM
Weathers5's Avatar
I'd like to see if my chain skipped a tooth, but I don't want to take the cover off. Is there really no way to do this without manually checking the marks?
Old Mar 3, 2025 | 02:51 PM
JacobChevys's Avatar
Whats making you think it skipped a tooth?
Old Mar 3, 2025 | 04:35 PM
Crank angle gauge (protractor) and dial gauge to measure valve lift .
Have a read of this
https://ls1tech.com/forums/generatio...ad-center.html
But it would be easier to just pull the cover and check tbh
Old Mar 3, 2025 | 04:42 PM
IGN-1A's Avatar
Default Split Overlap
Turn the crankshaft with a valve cover off, watch the rocker arms move, AND after the lifters are pumped up.
You will find one cylinder with its valves "part" opened (Overlap).
Mark the Dampner in four equal places, one which is TDC 0
That cylinder should have the rocker arms/valves at equal distance with a Split Overlap camshaft (most common)/
When one of the four marks matches the TDC 0 pointer
Old Mar 3, 2025 | 07:50 PM
Rich-L79's Avatar
The chain would have to be unbelievably loose/stretched for the chain to have skipped a tooth. And if it had, the crank and cam sensors would be causing codes in the ECU like crazy.
I would think a chain would break long before it would stretch enough to skip.
Old Mar 3, 2025 | 09:06 PM
Weathers5's Avatar
Ok. I'm getting a flashing CEL with no codes, and I'm having trouble diagnosing the issue. Maybe this one should be crossed off my list. Sounds incredible.
 Michael S. Palmer
Old Mar 3, 2025 | 09:07 PM
Weathers5's Avatar
Rough idle, random misfire, etc. This all started after I changed the oil pan gasket. I took the timing cover off to do that which required that I remove the crank pulley. Wondering if I the chain could've slipped during that process without me knowing it.
Old Mar 3, 2025 | 09:13 PM
It's pretty hard for the chain to skip teeth unless there was a YUUUUGE amount of slop, so I doubt it skipped any teeth.
You have other issues. You might just need plugs and/or wires.
Old Mar 3, 2025 | 09:21 PM
Weathers5's Avatar
Y'all are probably right.
Based on what I've done so far, I don't think I have any vacuum leaks and my MAF sensor seems to be working fine. So, my near term plan is to check compression then change my plugs, wires and o2 sensors. Then, I'll go through the crank relearn procedure since I never did that after my engine swap. I'll report my progress back to this thread. Fingers crossed.
Old Mar 3, 2025 | 09:29 PM
Yeah I forgot about the MAF sensor. It might be "working" BUT dirty.
Get some MAF cleaner from the parts store. It might help things too.
Also, get a bottle of Chevron Techron and put it in with the next full tank of fuel. I'm not normally an additive junky, but this stuff cleans fuel systems.
Old Mar 3, 2025 | 09:51 PM
LS1Formulation's Avatar
What vehicle are you working on?
Old Mar 4, 2025 | 10:34 AM
Weathers5's Avatar
Cleaning the MAF sensor was actually the very first thing I did. Unfortunately, didn't help noticeably.
I'll do that with the Techron. I've seen the same advice in other places too.
Weathers5's Avatar
2003 Silverado LS 4X4
Old Mar 4, 2025 | 11:53 AM
I knew as soon as you posted that it was a Silverado. Forget everything else you're doing and get a scanner on it that can do a crankshaft variation learn. It will most likely fix your problem. It is very common for Silverados to have unexplained misfires with no CEL. I have diagnosed this many, MANY times.
Old Mar 4, 2025 | 12:59 PM
IGN-1A's Avatar
Default Sloppy Chain
Hi Again, I would always fit the LS-92 Timing Chain Tensioner.
The single one will often break the spring.
What one do you have, is it new?
Old Mar 4, 2025 | 01:11 PM
Weathers5's Avatar
Thanks for the advice. I have HPTuners. So, once I change the plugs, wires and O2 sensors (need to do this anyway), I plan to go through the relearn procedure. Crossing my fingers that this is THE fix!
Old Mar 4, 2025 | 01:21 PM
Weathers5's Avatar
I have no idea. I had the timing cover off not that long ago, but I didn't really pay attention to the tensioner.
Old Mar 5, 2025 | 11:55 AM
Weathers5's Avatar
Since I'm going to check the compression soon (waiting on the weather to cooperate), does it make sense to do a leak down test, too? I was thinking since the misfires seem to be random, the leak down test isn't necessary. Probably true for the compression check, too but that should be quick and easy.
