Ptv contact cammed ls1
This setup shouldn't have PTV issues if everything is stock.
But apparently you do. Now you need to find out why.
Degree the cam or at least verify dot to dot.
Verify spring install height.
Then then check PTV.
There's only a few things that are going to cause every intake valve to kiss the piston.
