Cam question.
Old Jun 11, 2025 | 05:13 PM
The_Bishop's Avatar
Default Cam question.
I'm finally gathering the last bits I need to install the LS6 heads I have.
Original idea was to install the 5308 LS6 cam I have sitting on the shelf.
I am now considering using a different cam. The heads are already set up with dual coil .660 valve springs from Brian Tooley Racing.
Pertinent Info: LS6 Heads with the actual lightweight valves.Mild bowl blending, rocker arm bump removed. LS6 Intake, ported throttle body. SLP air filter housing. Car has: Yank SS3600 converter, 3.42 gears out back. Transgo stage 2 valve body kit in transmission. Racetronics 255LPH pump with the hotwire kit for fuel system. 1998 Camaro Z28. Dynatech headers, magnaflow cat-back. It's all in the signature.
I don't want to rev this thing to the moon. Currently looking at possibly a Titan 1. Anyone have any experience with the Titan 1 camshaft?
Old Jun 14, 2025 | 02:48 AM
Abs's Avatar
Abs
I have no experience with the titan 1 cam but when I was reading your post, the 8720 summit cam came to mind. 218/227, .600, .600, 112+2. Its like an ls6 cam on steroids IMO. Its a modern gm hot cam with high lift. Happened to look up the titan 1 and see its 218/222 on a 112+2 so very similar to the 8720. Pick your poison. I say go with the 8720. Lobes are more aggressive, which also yields more torque and power
Old Jun 14, 2025 | 06:45 AM
DUSTYWS6's Avatar
I would use the cam you got and save your money if your goal is to have a small cam. LS6 cam - no potential drivability issues and don’t have to worry about long term valve train issues. I’d take this peace of mind over the 10 hp difference that’s not really significant. If your goal is noticeable lope, the opinion is different.
Old Jun 15, 2025 | 06:34 PM
68Formula's Avatar
Either the Titan 1 LS1 or the Summit 8720R1 would be light years improvement over the 5803 in your setup with no driveability issues when correctly tuned. And they'll take better advantage of the Yank convertor. In fact, I would even suggest doing the Summit 8715R1 222/234 115+3 .600/.575 with the 3600 stall.
Old Jun 15, 2025 | 09:32 PM
Abs's Avatar
Abs
yes! I've been meaning to come back and say that but have had such a busy weekend. 8715 ghost cam would be perfect. Not as good as the others down low but doesn't have to be with that converter
Old Jun 17, 2025 | 10:23 AM
Summitracing's Avatar
LS1Tech Sponsor
OP,
We like what @Abs and @68Formula are thinking here. We wouldn't hesitate dropping in the SUM-8720R1 or SUM-8715R1. The 8720R1 would come in a little sooner around 2200-2500 and run out to 6,500+. In comparison, the 8715R1 would be more of a 3000-6,800+ cam. You have the bolt-ons and mods to make either one shine. They will both have smooth to noticeable idles with great manners and be easy to get along with. With the 3,600 converter we'd probably lean on the 8715R1 since it extends the range out a bit. You have good .660" lift duals, so you're good there. You'll want some upgraded pushrods for either. A 7.400 or 7.425" should work, but we recommend measuring first. Lifters would be a good idea as well. We'd recommend our SUM-HTLSKIT2 or SUM-HTLSKIT3. Both are lifter and tray kits with bolts. The HTLSKIT2 comes with Delphi LS7 lifters and the HTLSKIT3 comes with drop-in Morel 7717 lifters.
Let us know if we can be of any further assistance. We'll be happy to help!
__________________
800-230-3030
www.SummitRacing.com
