Compstar vs magnum
Old Jun 14, 2025 | 05:37 AM
BCNUL8R's Avatar
Default Compstar vs magnum
What is the difference between them?
Im guessing compstar made in China and magnum made in the USA.
Beyond that what is physically different about a USA forging vs China that makes them stronger?
Old Jun 14, 2025 | 12:20 PM
IGN-1A's Avatar
Default H Beams ONLY
I always fit an "H" beam rod; they make MORE HP.
Old Jun 14, 2025 | 01:21 PM
BCNUL8R's Avatar
I’m talking about crankshafts, thanks.
Old Jun 14, 2025 | 02:38 PM
IGN-1A's Avatar
Default Best Crankshaft
OK, I would always fit a Marine Crankshaft.
Old Jun 14, 2025 | 03:10 PM
BCNUL8R's Avatar
That wasn’t the question. Read the op again. What is the physical difference between a compstar and magnum crankshaft that makes the magnum stronger?
Not sure if you are a real person or an ai bot ?
Old Jun 14, 2025 | 03:18 PM
Y2K_Frenzy's Avatar
To find out I think it’d take more digging than anyone on here can do. I’d almost be willing to bet though that the American made option is made with Chinese metal.
Old Jun 14, 2025 | 03:22 PM
He's real. I've talked with him on the phone a few times. Nice guy.
Old Jun 14, 2025 | 03:35 PM
IGN-1A's Avatar
Default Metal Manager
Y2K IS CORRECT !
Both Forgings come from China
I use Billet Steel
Old Jun 14, 2025 | 04:09 PM
wannafbody's Avatar
If it has a Made In USA label on it it's got to be made with US sourced steel. Otherwise it should say manufactured in the US with foreign components or something similar.
Old Jun 14, 2025 | 06:00 PM
BCNUL8R's Avatar
Pretty big price difference if both are forged in China. Quick search shows all cranks are inspected in the USA to verify quality and the magnum may go through additional heat treat processing.
Old Jun 14, 2025 | 09:53 PM
Y2K_Frenzy's Avatar
Y2K IS CORRECT !
I use Billet Steel
Everything does..
Old Jun 14, 2025 | 09:58 PM
Y2K_Frenzy's Avatar
Maybe ask them where they get their blanks.
I used to work at a bread factory (in TX) and a lot of the raw ingredients came from overseas. It was American made bread though. Well, some of us were Americans making it.. 🤦🏻‍♂️😂
Old Jun 15, 2025 | 11:06 AM
BCNUL8R's Avatar
I found this article from 2024: https://moparconnectionmagazine.com/...ance-products/
They say Compstar cranks are forged overseas with Callies dies and raw steel mixed to Callies specs. The cranks are then inspected here in the US.
It also says Magnum cranks are forged and machined here in the US.
Old Jun 15, 2025 | 02:56 PM
lafnatu's Avatar
Old Jun 15, 2025 | 04:09 PM
01CamaroSSTx's Avatar
Sonny Bryant billet crankshafts are really nice then again so are Lunati and Callies billet steel crankshafts.. They all have one thing in common too they're upwards of 5K for them.
Old Jun 16, 2025 | 03:17 AM
BCNUL8R's Avatar
The question wasn't what is the best crankshaft for an LS...lol No sense putting in a crankshaft that will handle 1000 more hp than the block itself or what the heads can seal.
I was just considering the 8 cw compstar and trying to decide if going a step higher to the magnum was worth it. For my application 1200-1300 rwhp I think the compstar is probably good enough.
Old Jun 16, 2025 | 06:05 AM
Busted Knuckles's Avatar
"I always fit an "H" beam rod; they make MORE HP."
I'm afraid I have to call BS on this.
Rods don't make HP, it's everything above them plus the camshaft that makes HP. Rods just connect the piston to the crankshaft, period.
Old Jun 16, 2025 | 07:16 AM
BCNUL8R's Avatar
I would think the lightest rod possible would make more power as long as it can actually handle the power without breaking or bending.
Kind of like a 10 bolt rear robs less power than a 9” as long as it can actually handle the power levels of the vehicle.
Old Jun 16, 2025 | 08:51 AM
Different rear ends ABSORB different levels of power via friction,
That reasoning doesn't apply to connecting rods
They don't affect power level
Old Jun 16, 2025 | 10:24 AM
BCNUL8R's Avatar
You don’t think a lighter rotating assembly would make more power than a heavier rotating assembly all else being equal?
A 4l80 robs more power than a 4l60e as well I’d bet. Heavier driveshaft robs more power than a carbon fiber shaft. Turning more weight takes more power.
