Enginetech still a good brand/supplier?
Stumbled across a marketplace listing for a 6.0 shortblock that needs new pistons. Was hoping to find a used set of OE pistons but every used set is in just as bad if not worse condition than the current pistons in the motor. Rockauto has enginetech pistons listed at 160 for a full set, which seems like a great deal. I've found a couple of threads on here that are pretty old saying enginetech is good for a stock/mild rebuild, but wanted to make sure nothing has changed in the last few years. Any feedback?
Beware that some of them have a shorter compression height than factory pistons. If that is the case, I'd just use a thinner head gasket.
I have some OE flat top with valve reliefs.
GM Part number 89060486 is 1 piston assembly. Flat top for the 3.78 bore on the 4.8/5.3L with floating pin style rods
The Flat top with valve relief was for the VVT style engine which I believe was only in the 5.3L
