Quench questions
Aluminum blocks "grow" more that Iron blocks. Some race motors go much tighter on the quench. just depends on the application.
I recall a conversation I had with Tony Mamo about a motor he built with tighter quench and he stated when he removed the heads you could see the out line of the piston where it was just barley knocking the carbon off the deck of the head and leaving an in print in the carbon. It was not touching the head and it never made contact but damn was it close... Again built for a specific goal in mind.
.035 in an aluminum is fine.....040 probably better if your running cast iron
The aluminum engine block expands more so the real quench is closer to .040 at operating temps
Cheers,
Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
